Old 12-06-2018, 06:01 PM
ejl6658 ejl6658 is offline
Default 353 45" 3000 series snowblower skids
Bought these new skids for my 3000 series blower. They are Robalon skids and are lightweight and this is the description on Small Engine Parts Warehouse site.
" Robalon replacement snowblower skid shoes are salt, age and wear resistant. Robalon lasts 2-5 times longer than painted steel, and 3-4 times longer than stainless steel or injected molded plastics. They have been factory wear tested for proven long life. No marking on concrete. Will not scratch pavers or exposed aggregate. "
Time will tell how well they perform and how long they will last. I have 800 ft gravel driveway.
Old 12-06-2018, 06:04 PM
1 3/8" wide.
Old 12-06-2018, 06:28 PM
You would think they would make them with more meat so the holes are not close to the wear edges.
I see they make moldboards for plows also.
Up to 534 and counting...
Are they expensive....???
Old 12-06-2018, 06:58 PM
Default 353 snowblower skids
$59.99 for the pair plus shipping, a pair of steel OEMs are about the same price.
Old 12-06-2018, 07:00 PM
They claim they last 2-3 times longer than steel. We'll find out.
Old 12-06-2018, 07:18 PM
Google search for Robalon material.
ROBALON® – sliding and wearing plastics for industrial use
ROBALON is a highly wear-resistant UHMW-PE-based material.
Robalon can be modified in various ways in terms of sliding behavior and chemical and UV stability.
We produce ROBALON on sinter presses in panel form at our plant in Oepping.
These panels are refined on profile milling machines and CNC milling machines and lathes.
Characteristics: Very high wear resistance, low coefficient of sliding friction, very high impact strength, low density, virtually no moisture absorption, limited weldability, resistance to exceptionally strong impacts, outstanding chemical resistance, self-lubricating characteristics, good stress crack resistance, can be used to a temperature limit of -200°C
Very good resistance to acids, bases, alcohol, aldehydes, organic solvents, and grease
Limited resistance (swelling) to some hydrocarbons
No resistance to strong oxidants such as fuming sulfuric acids, concentrated nitric acids, nitrosulfuric acids, chromosulfuric acids and halogens, and some cleaning agents. Risk of formation of stress cracks.
Typical ROBALON applications: Chain and belt guides, curved guides, slide parts, linings, sprockets for snow groomers, Wearing plates for vibrators and rammers, bushings
Old 12-06-2018, 08:58 PM
Gompers Gompers is offline
Interesting. Always nice to find a new parts source.
125, 127, 2x IH 682, 2x IH 782, 2084, 3225, 2x3240
Old 12-07-2018, 06:37 AM
Edward:
Thanks for the update.
Old 02-20-2019, 01:01 PM
Joelk Joelk is offline
How are these working out.
Are they wide enough to keep the cutting edge out of the gravel?
How are they wearing?
