I am looking for some Data on your typical Hydraulic Angle Kit for the IH Dozer Blades.
The cylinder, as I understand, is Bore: 1.50" x Stroke: 7.50" What I would like to know is the following Dimensions, pin center to pin center: Xa = Full retraction Xb = Full Extension
I had these saved in my files and do not recall the source. You may want to verify these as I personally did not draw them. However they look to be accurate and seem credible.
Mike |
THANK YOU.....
I had the drawings on the above brackets, just not the cylinder. ![]()
![]() Quote:
https://www.surpluscenter.com/Hydrau...-9-4410-08.axd It has the same collapsed length and 8" of stroke. The pins holes are larger and will need a bushing or larger hardware if you are making the mounts.
3240 870hrs - 48" 289 deck, front hitch, 3 hyd circuits, 54" blade w/hyd angle, 45" 2-stage snow blower, Sims cab, 5 42# suitcase weights and 70# rear wheel weights GT3204 207hrs - 48" 289 deck, 45" 2-stage snow blower, 54" blade and angle cylinder 3204 580hrs - 48" 289 deck - Parts Tractors - 3208 560hrs (rusty) 3 hyd circuits, 3pt hitch, 44" deck - 3165 rust free roller 1650DH 54" blade, Xtreme cat-0 3pt, 44" deck, filled 23x10.5-12 Tru-Powers |
