Old 07-18-2010, 12:53 PM
jeffscub's Avatar
jeffscub jeffscub is offline
Default balance gears
i was just looking at an engine diagram and was looking for the balance gears, does a 77 1200 12 hp engine not have balance gears? i tore an early 70's 12hp off an economy powerking down and it had balance gears. of all the different models that used the ol iron horse, what is the standard of say balance gear to: year model, make of tractor, hp, application it will be used on? am i missing the obvious?
'72 108 w/ 38" HIGH speed deck, '77 1200QL w/ homemade grader blade, '79 1450 44" grass tamer, '70 sears super 12 w/ 3pt , 19?? 100 w/ extra toys, 69' economy powerking 14 horse w/ FEL, 65' economy powerking w/ toys, 1982 allis chalmers 716
Jeff
Old 07-18-2010, 02:38 PM
dross dross is offline
Default gears
I have'nt seen every QL engine out there but the ones I have seen had the boss' for the pins but they're not drilled.
The WF had a lot of them but not all and I don't know what the cutoff is for sure either.
Old 07-18-2010, 02:58 PM
gcbailey's Avatar
gcbailey gcbailey is offline
Didn't IH start putting balance gears in the 14HP starting with the 147? I don't know if they went back on the smaller engines on the wide frames and put them in or not.....
Gary
