Old 11-06-2018, 08:16 AM
BangBang1977 BangBang1977 is offline
Default 1976 1650 wheels bushings
Hi first forum ever so please forgive me if I post out of line.
I have a new to me 1976 1650 that runs great and will be put to work on our new property. I am wanting to do some general maintenance to keep it in good working order. First order of business is the front tires have a little slop in them, so I pulled rims and tires off to find it has bushings not bearings.
I’ve done a general quick google search for 1976 1650 bushings but not having the best of luck.
My question is do I need the model number of tractor to search for these parts? And any advice would be welcome, Thanks.
Old 11-06-2018, 08:26 AM
It should have bearings. If you have bushings someone has replaced the wheels.
Old 11-06-2018, 08:29 AM
First, welcome to OCC.....
The 1650 did NOT roll out of the Factory with Front Wheel Bushings. Must be a previous owner modification.
The 1650 DID use front wheel Bearings. During the course of production, they are started out with 3/4" bore bearings, then switched to 1" bore bearings.
* Serial Number <632501 used 3/4" Bearings
* Serial Number 632502> used 1" Bearings
IF.....you want to go back to original, you have to acquire the proper rims and get new bearings.
IF...you want to fix what you have, then take careful measurements and buy bushings from a supplier like McMaster-Carr.
Old 11-07-2018, 08:30 AM
Mudrig150 Mudrig150 is offline
If it's anything like my tractor it probably has the original bearings missing the center parts.
Old 11-09-2018, 03:01 AM
guyina4x4's Avatar
guyina4x4 guyina4x4 is offline
https://www.cubcadet.com/equipment/A...1#/s/CUT/1650/
JD x475
