Old 04-25-2009, 10:26 PM
wig wig is offline
Default KOHLER KT17 Rebuilding Questions
I need to re-ring my motor. First are the after market connecting rods and rings worth using?Next, the pistons are std. size, but not sure which size connecting rods to use.How do I know which connecting rods to use?
Old 04-26-2009, 01:04 PM
wig wig is offline
Default measuring the crank
will I have to pull the crank, just to mic it?
Old 04-26-2009, 01:14 PM
Personally, I can't afford OEM connecting rods for these things...when I put my M18 project back together, it's getting aftermarket rods and rings. Connecting rods for these things only come in standard and .010 undersize. The undersize rods have a small hole drilled in the web. I'd also replace the governor gear and mains while you're in there.
