Old 10-10-2018, 12:34 PM
Mudrig150's Avatar
Mudrig150 Mudrig150 is offline
Default Bolt sizes
Looking for the following bolt sizes on a quietline:
Tunnel cover
Muffler box (the small ones)
Baffle (engine tins)
I'll add more in the future as I find missing bolts.
Cubs: 1986 CCC 1912 Kawasaki swap, 1984 MTD 782D, 1985 CCC 1210
Other tractors: 69 Deere 3020, 69 Deere 140 H2, 64-ish Burns B60
Old 10-10-2018, 12:53 PM
cooperino's Avatar
Buddy, They are all standard bolt sizes.. Just get some bolts and try threading in if you don't know sizes by eye.. Seeing what size something is threaded by eye just comes with time and exp
Old 10-10-2018, 01:06 PM
This link will list the sizes.
https://www.cubcadet.com/webapp/wcs/...0-A/0019100005
Up to 534 and counting...
Old 10-10-2018, 01:49 PM
Click on the link above, that says "Cub Cadet Parts & Service Lookup". It will give you all the parts information you need.
As Bill said, any well equipped Hardware or Fastener will have them too.
Old 10-10-2018, 01:54 PM
Mudrig150's Avatar
I can't remeber exactly, but isn't the quietline muffler diameter 2.5" or 1.5"?
Edit: It's 1.5"
Old 10-10-2018, 02:06 PM
Mudrig150's Avatar
What bolts should I replace in the tractor or change to a different style? I'm probably going to buy new motor mount bolts (cradle and oil pan) as mine are probably stripped and warped from the engine buckin like a bronco.
Old 10-10-2018, 03:20 PM
Replace the Nuts and Bolts as needed.
Old 10-10-2018, 04:07 PM
Dstein16's Avatar
Dstein16 Dstein16 is offline
I think for questions like this it would be best to check all other resources first. You have the tractor right? Go out, pick up some tools and size up the nuts and bolts at any hardware store. I personally go to Tractor Supply for my hardware. Easy to find and you can buy them individually. If you can’t do that, use the link above, or use Parts Tree, or you might get lucky and find some valuable info in the service manual. You will learn much faster by doing this, trust me. I was a young enthusiast just like you not many years ago and actually doing the work (not being spoon fed answers) really goes a long way.
Don’t get me wrong, most if not all of the folks here are willing to help and are VERY knowledgeable. If you get stuck using all your other resources first, then ask here. These guys are great at answering challenging questions.
-Derek
Cub Models: Original, 100 (x3), 1282, 1572, XT1 LT46
Old 10-10-2018, 05:05 PM
john hall's Avatar
I think the tunnel cover is held on by #12 (probably 24 pitch). Don't quote me on that. It is a RARELY used bolt. For that reason, when folks lose them they tend to shove whatever sheet metal screw/wood screw they had in their that they could make tighten down. I would think that the parts book would tell you exactly, or if you click on a part, you should get a more exact description.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 10-10-2018, 06:48 PM
cooperino's Avatar
Last few I got had some sheet metal zippy's "self tappers" in there. Not correct but they screwed up the threads lol. Pun intended
