Old 09-19-2018, 07:35 PM
nutzboutoldies's Avatar
nutzboutoldies nutzboutoldies is offline
Default K321 Crank End Play
I'm putting the crank in today and when checking the end play with the gasket and 3 paper shims I'm at .018, the manual spec (I believe is) .003-.020. The paper shims that came in the gasket kit are .010. I removed one of the paper shims, reassembled the crank, and now the end play is .008. My question is should I run on the tight side or loose side. I guess if the gasket kit had a .005 shim I could get closer to the middle of the spec.
Steve
1450
QA42A Thrower
44A Mower
Old 09-19-2018, 08:09 PM
You're good where you're at. I'd rather have it to the tight side.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 09-19-2018, 08:35 PM
Be sure your crank bearing on the flywheel side that it has not moved.
Old 09-19-2018, 10:34 PM
As long as you are between .003" and .020" it's fine. Like Tim, I prefer it on the tight side. This is one spec you don't want to shoot for the middle. Actually, most all specs I prefer to shoot for the tight side, except maybe valve adjustment. As the valves wear, they tighten the gap, so I would prefer they be closer to the loose side than the tight side. Especially new valves because they will tighten up a bit when the seat.
