Old 09-10-2018, 01:20 PM
gscott gscott is offline
Default Brain Storming Oil Cooler
I am not an engineer or expert. I was brainstorming on putting an oil cooler on a k-series Kohler.
Looking for pros and cons...
Could I use a mechanical fuel pump to pump oil through an oil cooler?
Perhaps by placing an NPT fitting in the sump of an oil pan, route it to the "fuel" pump, then back out to an oil cooler, then from the oil cooler to an NPT fitting on the block?
One major question...is the pump strong enough for oil?
Again, just brain storming......
Old 09-10-2018, 01:44 PM
Unnecessary.
Not likely the fuel pump will pump oil anyway.
Nothing to gain.
Too much involved for no gain.
Old 09-10-2018, 01:52 PM
cooperino's Avatar
Is your K series running hot??
Old 09-10-2018, 01:55 PM
Merk Merk is offline
Why would you want to do this?
Run an 30 weight dino oil in it and it shouldn't have any problems. I use Kohler oil in all my K-series engines.
There is something wrong-not set right if the engine is running hot.
Project Uncle Dick
Cub Cadet 70
Old 09-12-2018, 01:06 AM
Default Thanks for the replies
I appreciate the feedback guys. No...engine running well. was just brainstorming. I think the best response was a lot of work with no gain.
Thanks again.
Old 09-12-2018, 02:05 PM
If you're gonna go through all that trouble you better add a filter.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 09-12-2018, 02:14 PM
A fuel pump wouldn't make enough pressure to push oil through a filter. I really don't think a fuel pump would pump 30wt oil at all..... but I never tried it. Even if it did, it's only a few cc's per stroke. 2, maybe 3 at most. It would pump so slow, you wouldn't need a cooler. It would cool just going through a steel tube 12"-18" long.
Big waste of time anyway.
Old 09-12-2018, 02:47 PM
It was a joke. You need to relax a bit.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 09-12-2018, 03:09 PM
Ok.... I get it....... But I didn't want anyone taking it seriously.
Old 09-12-2018, 03:16 PM
cooperino's Avatar
It won't.. We tried using a electric fuel 12 psi pump with 5/16 inlet and outlet to transfer some oil. It started to pull it but as soon as it hit the pump it stopped.
