Old 08-29-2018, 06:40 PM
sorner's Avatar
sorner sorner is offline
Default Cub 73 PTO clutch stuck
I’m working on this 73 for a friend and the PTO clutch is stuck engaged. I can’t get it to pop out. Any tips or tricks? Or is it disassembly time?
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
GREEN 317 with integral sleeve hitch, front hydraulic
Old 08-29-2018, 06:47 PM
Is it adjusted properly? I would try mowing with it disengaged and see if it breaks lose on it's own.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-29-2018, 06:49 PM
sorner's Avatar
The adjustment was too tight, I loosened it up and there’s a good inch between the button and the lever. I mowed with it and it didn’t pop out. I can wiggle it side to side in the “teeth” but it’s not popping out to disengage.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 08-29-2018, 06:51 PM
The lever pushes on the button to disengage the PTO, it will never disengage is the lever is an inch away.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-29-2018, 06:52 PM
With the hand lever in the forward position adjust the rod until there about an 1/8" between the arm and the button on the PTO.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-29-2018, 07:00 PM
sorner's Avatar
Maybe I need to read up on how these things work. I have never seen one before up close. I assumed with it forward and space released it.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 08-29-2018, 07:09 PM
Negative. Forward is engaged and back is disengaged. Put the handle forward and adjust the rod till there's a little under an 1/8" gap and then pull the handle back, it should disengage.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-29-2018, 07:40 PM
https://www.onlycubcadets.net/forum/showthread.php?t=9
Old 08-29-2018, 07:44 PM
That's a good way to burn the buttons up.......
Old 08-29-2018, 07:51 PM
I've only ever had to do it once and it only took about two minutes to break free, that PTO still works great 5yrs later.
Pap's 100
Restored 108
1211 Dual Stick
1050
