Old 08-18-2018, 07:52 PM
Jbo_c Jbo_c is offline
Default 122 and 126 deck
Will a 42” deck from a 126 fit a 122? I have a 126 with a blown motor and There’s a 122 runner with a bad deck near me. My 126 has a 42-1 114 deck. Will it fit if I get the 122?
Looked but couldn’t find a good cross-reference.
Thanks.
Jbo_c
Old 08-18-2018, 08:33 PM
Yes It will fit, you can use the donkey drive from the 126 on the 122 also.
You will have to remove the older style donkey drive from the from the 122.
Belts sizes are here in the tec. section
Here is my 122 with one on it.
Hee Haww
Old 08-18-2018, 10:16 PM
Pin the deck on the donkey? Wait, pin on deck and the donkey? Hold on, I got it now, QA donkey and the deck.
Btw you’re also going to have to bolt the donkey on the 122 as Franks bolts are not present.
LP why does it look like you have a 2 by 4 on your clutch pedal?
Old 08-18-2018, 10:36 PM
The banter is cool, but I’m a little confused. Is it a direct fit or will I have to use pieces of both to make it fit? Are there pieces I’ll need that aren’t on either one? I’ll pass if I can’t make it work with just the parts on the two of them.
Thanks for the quick responses.
Jbo
Old 08-18-2018, 10:45 PM
Yes, it will work.
Old 08-18-2018, 11:32 PM
Jbo
Take entire mule drive (what Lew is referring to as “donkey”), the deck carriage with the pulleys from the 126 and install on 122. The 122 will not have Frankenstein bolts, those are big shouldered bolts that 126 has that engages it to the mule. The 126 has a quick release carriage, pull lever in front and mule slides forward disengaging it from the Frankenstein bolts. 122 originally came with a different mule, non quick release, it has a pin on style deck with bolt on mule. Make sense? Transfer mule and deck from 126 to 122 and bolt mule on, there are threaded holes in 122 frame that will line up. Both tractors are narrow frame models ones just earlier than the other.
Old 08-18-2018, 11:51 PM
Good explanation Mr Alvy, I like the pin the deck on the donkey analogy.
Old 08-20-2018, 08:49 AM
Thanks. That makes good sense.
Now, though. I’m wondering if it might be almost as easy to just swap the engines. . .
Jbo
Old 08-20-2018, 10:07 AM
Duh.
Or buy a new engine. I know a guy who sells them....
