Old 07-31-2018, 10:19 PM
CUBRAT CUBRAT is offline
Default Cub Cadet 104 Clutch Drive Disc Spring (s)
I've read a few threads on these drive disc springs. Most people say to install them on the engine side of the drive plate.
In the service manual, it clearly shows it installed on the pressure plate side. Also, in the pic, I can only see one spring.
Anyway, what I am getting at, what is correct?
Old 07-31-2018, 11:12 PM
If they are on the flywheel side and they break, they will stay on and you have to pull the motor loose to change them. If they are on the pp side, you can change them if they break. Your choice. They are just anti-rattle clips. Non essential.
Old 07-31-2018, 11:28 PM
I always install mine into the garbage can.
Pap's 100
Restored 108
1211 Dual Stick
1050
