Old 07-26-2018, 01:08 PM
zimm17's Avatar
zimm17 zimm17 is offline
Default Source for new wheels and turfs for 149?
I've been away from the tractor for a few years since I restored it. My father is going to use it to cut his grass in a few months as they have moved to a larger property.
The tractors is currently on ags/wheel weights and tri-ribs. I'd like to save those and buy a new set of wheels and turfs for grass.
Who makes new wheels that will fit a 149? What size do I want to get the fattest turfs that will fit (and what sizes should I get?)
1973 Cub Cadet 149
2023 John Deere X590
Farmall B sitting in relative's barn
Old 07-26-2018, 01:48 PM
The tires you have on it are fine to cut grass with. No, they will not tear up the yard.
What you buy depends on what you want. Several different tire size choices for a 149. What sizes are on it currently?
I'd leave it as is though....
Old 07-26-2018, 01:51 PM
zimm17's Avatar
I put new firestone tri-rib 16x6.50x8 on the fronts
Rears are 23x8.5 carlisle tru-powers with weights.
It'll be 1.5 acres in Florida so it's mostly sandy. I'm worried the tri-ribs will carve up the ground. They sure tore up my yard when it was wet in Virginia.
1973 Cub Cadet 149
Old 07-26-2018, 02:15 PM
Maybe your toe is not set right.
I don't have any issues in Illinois.
Old 07-26-2018, 02:29 PM
Try the Miller Tire Company
The widest tire for the rear was the 23-10.50x12 and 16-6.50x8 for the fronts.
IF you are looking for an extra set of rims, try the sponsors at the top of the page.
Old 07-26-2018, 05:06 PM
TNTs CC TNTs CC is offline
I've seen a 169 running 24-12x12 Turf savers and 16-7.50x8 Turf masters, they seemed to fit fine.
3240 870hrs - 48" 289 deck, front hitch, 3 hyd circuits, 54" blade w/hyd angle, 45" 2-stage snow blower, Sims cab, 5 42# suitcase weights and 70# rear wheel weights
GT3204 207hrs - 48" 289 deck, 45" 2-stage snow blower, 54" blade and angle cylinder
3204 580hrs - 48" 289 deck - Parts Tractors - 3208 560hrs (rusty) 3 hyd circuits, 3pt hitch, 44" deck - 3165 rust free roller
1650DH 54" blade, Xtreme cat-0 3pt, 44" deck, filled 23x10.5-12 Tru-Powers
Old 07-27-2018, 07:21 AM
That would be a Non Cub Cadet modification.
Old 07-27-2018, 07:59 AM
sawdustdad's Avatar
It's been my understanding (though I've never tried it myself) that 24-12x12 tires will fit but just barely and, in some cases, by shimming up the fenders a bit.
Old 07-27-2018, 10:20 AM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
I am in Florida too, my 4 acres is fine sand also.
I only have native, natural green field grass slowly turning into a lawn.
Which was an overgrown unmaintained field 18 months ago.
I have to run what they call "sand blades" on the deck to cut down on the sand storm created by high lift blades. I figure it will be three years before it will fill in and I can go back to regular blades.
Anything but turfs front and back does damage to bare spots. I am running the smooth ribbed wide fronts, and the O.E.M. Firestone "snow tire" style 23x8.5 rears.
If your Dad's place has nice thick established lawn, I would run what you have now before buying new tires and rims. Then decide.
But if it is newly created, seeded yard or like mine above with bare spots then you might want to go with different tires.
