Old 07-18-2018, 08:42 AM
RLW_LT2138 RLW_LT2138 is offline
Default LT 2138 forward/reverse shaft broke
I seem to have a broken forward/reverse shaft 603-0697.
Has anyone else had to replace one of these?
Are there any other parts that I should replace while I've got it apart?
I was wondering about washers or bearings. I do not want to get into this and have to make a second parts order.
Thanks
Rich
Old 07-19-2018, 08:12 AM
Merlin2014 Merlin2014 is offline
I recently acquired a 2185 and have been checking things out under it. Nothing major is broken on mine in regards to the forward/reverse mechanics but I do see where several of the little bushings are either worn out or missing from it. If I was ordering parts for it I would probably order several of the different bushings for that system. In my case it would be part numbers 941-3073 and 941-3074. Just a suggestion. Hope this helps.
Old 07-19-2018, 05:38 PM
Thanks Merlin,
That is what I was thinking also. The only way I can see this shaft breaking is for the bearing to have failed and the ware in the shaft weakened it.
Old 07-20-2018, 09:40 PM
I took the mower deck off tonight. The real problem was a missing shoulder bolt. A new one has been ordered. I'll put something there to get it going until the correct one gets here.
