Old 07-11-2018, 09:25 AM
ynpmoose ynpmoose is offline
Default Return to neutral
This is a HDS 2155 with hydrostatic. When I let off the reverse pedal, it snaps back to neutral pretty hard, almost too hard. When I let off of forward, it slowly or sometimes way too slowly (several seconds) comes back to neutral. Is there an adjustment or spring that controls this? Thanks!
I think this is also why my cruise control won't stay engaged. There isn't enough return tension to keep the cruise teeth engaged. It will engage, but after a few seconds, the lever creeps back to disengaged. I cleaned out the teeth and it works fine if you hold the lever down manually.
HDS 2155 15HP 42” Hydro Shaft-drive
Old 07-11-2018, 09:35 AM
Did you get under the tractor and look to see if you see a spring? Maybe a little shock on the hydro control levers? I think a quick look underneath and you will answer your own question pretty quick and easily.
Old 07-11-2018, 09:39 AM
There is a small pneumatic cylinder listed as a "damper" in the parts list that is the only thing that seems somewhat obvious to me. I guess I was hoping for some confirmation before throwing $50 away on a unnecessary part if this was just adjustment-related.
Old 07-11-2018, 09:41 AM
There is a small pneumatic cylinder listed as a "damper" in the parts list that is the only thing that seems somewhat obvious to me. I guess I was hoping for some confirmation before throwing money away on a unnecessary part if this was just adjustment-related.
You can't adjust a damper. Just like a failed shock, they go bad. If the neutral return spring is intact, the linkage is well lubricated, then not much else it can be.
Old 07-11-2018, 06:58 PM
Merlin2014 Merlin2014 is offline
Moose, I haven’t performed the procedure but on page 21 of the owner’s manual it refers to a problem similar to the one you are describing and walks you thru the steps to correct it.
