Old 07-07-2018, 03:31 PM
ynpmoose ynpmoose is offline
Default Transmission filter change question
I just picked up this HDS 2155 a few weeks ago with about 630 hours. The last known trans filter change is unknown, but the fluid on the stick is very clean. Can I change the filter without a complete draining? If so, about how much new fluid do I need to have on-hand to refill?
HDS 2155 15HP 42” Hydro Shaft-drive
Old 07-07-2018, 08:13 PM
Merlin2014 Merlin2014 is offline
Others will be along that are more knowledgeable than me but in my service manual it says 6qts of the 737-3120 (Cub Cadet Drive System Oil). The nearest Cub Cadet dealer to me is asking $14.50 per quart for it. Hope that helps.
Old 07-08-2018, 11:31 AM
Would you change just the filter on your car?
Old 07-08-2018, 10:29 PM
It always "looks" clean. Open it up, and drain the fluid, you'll see it ain't clean. IF you're changing the filter, for gosh sake, change the fluid as well...
Old 07-09-2018, 10:32 AM
Thanks for the sanity check. It just seemed weird the way it was stated. To change the filter without mention of the fluid. I guess I was just over-thinking what should have been obvious.
Old 07-09-2018, 11:09 AM
This might help:
https://www.youtube.com/watch?v=Fg9EwApidvg
