Old 06-03-2018, 09:41 AM
jpm900ss jpm900ss is offline
Default 128 Cub Cadet mower deck blades
I'm looking for replacement blades. The deck has three that measure close to 15 1/4 Inches. ID Number on the deck is: 441U1112
Old 06-03-2018, 09:46 AM
cooperino's Avatar
I have seen a lot of praise from members here of the gator blades..
http://en.oregonproducts.com/pro/products/oep/G6.htm
I have personally not used them but based on what members here have said, they will be my next set.
Old 06-03-2018, 01:41 PM
mortten mortten is offline
I believe you will find that Gator blades for a 44 or 50 deck are NLA.
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 06-03-2018, 02:09 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
Hello!
and look here:
http://www.ccspecialties.org/deckblades.html
Old 06-03-2018, 03:23 PM
On the Gator vs conventional:
It is my findings that
the gators will cut the grass up into smaller pieces making it disappear faster, and work great mulching/making leaves disappear in the fall.
The negatives are the "fingers" don't stay sharp very long and wear fast.
Also they don't have as much "suction" to pull the grass up straight if it is heavy/wet, and they don't throw the grass as far out of the deck as conventional blades do.
I use them selectively as needed, as they change in just a few minutes with an impact wrench.
Now this is based on 50 "A" & 50 C" decks.
I swear by them in the fall mulching leaves.
Old 06-03-2018, 04:22 PM
#1 son has 'em on his Z turn and his lawn always looks like crap.
I'll take my 44A any day even if it does take me a little longer to get the job done.
