I'm having a problem with my Cub Cadet. The blades only seem to engage when the lap bars are in neutral. When I pull them up and try to go forward the mower will go, but the blades stop. Also the mower has a noticable shake only when blades are engaged.
I replaced the PTO clutch last year and it worked fine until one day it just stopped in mid-mow. I have tested the clutch, and it is at 3.4 ohms. Any help and suggestions are much appreciated! |
Not many Cadet ZTR users here. If you have a bad vibration when you engage the deck, its probably a bent blade, loose blade, spindle bearing gone, belt coming apart, idler pulley (or its mount or spring tensioner) or if its shaft drive, a Ujoint. you should be able to check all of that in just a few minutes.
