Old 04-28-2018, 03:47 PM
IHCubCadet147's Avatar
Default 147 Steering Adjustment
My 147 steers sharper left than right. Is there any adjustment to fix this?
Old 04-28-2018, 06:02 PM
DeltaCub's Avatar
DeltaCub DeltaCub is online now
Go through the steering box and repair/replace any worn parts. Pay particular attention to the steering gear follower. Once you have the steering box rebuilt and lubed, check all of your drag link ends and tie rod ends...replace any worn out items. Make sure your drag link arm on the left spindle is tight and not sloppy. Adjust your tie rods for proper toe in. Finally, adjust your drag link ends so it steers equally turn to turn. I find it easier to adjust items in the last step with front wheels off the ground. One other thing to remember...grease the the front spindles so they turn freely in the axle. Have fun.
Queen Of The Quietlines!
Old 04-28-2018, 06:13 PM
I know the whole thing needs to be rebuilt, but can I just adjust the drag link ends for now until I can rebuild it? Will that fix my problem? And will the service manual have directions for this?
Old 04-28-2018, 06:28 PM
DeltaCub's Avatar
Adjusting the drag links may help. Yes, the service manual is your friend!!!!!!!!
Old 04-28-2018, 06:34 PM
Ok, thanks.
