Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Briggs & Stratton Engines
Old 04-22-2018, 04:26 PM
Default 14hp vanguard rebuild.
I got the engine out of the scrap yard 1440 and it has a broken connecting rod. The engine got some water in the one cylinder which rusted the bore a bit, I don't really have anything at home to clean it up with but I suspect it would need bored. The crank doesn't look bad but I can't get a good look at it since it's still in the block and I don't have an impact here to get the flywheel nut off. Are these engines worth rebuilding? I've found .010 pistons new and plenty of good used parts.
Pap's 100
Restored 108
1211 Dual Stick
1050
