Old 04-13-2018, 03:51 PM
Richs72 Richs72 is offline
Default Model 72 steering issue
The steering on my 72 has a great deal of slop in it. Is there an adjustment to eliminate it?
Old 04-13-2018, 04:06 PM
The slop is likely in three places, the steering box, tie rod ends and the axle pin. The box can be adjusted and the procedure is in the manual. Tie rod ends can be bought from various sources. The front alxe pin can be replace with another but you will need to squeeze the C channel with a bolt or big c clamp to tighten it back up.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 04-13-2018, 05:06 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
The drag link on the left spindle gets very sloppy too. Replace both parts.
Queen Of The Quietlines!
Old 04-14-2018, 10:14 AM
thanks for the help
