Old 04-05-2018, 05:52 PM
thadscub's Avatar
thadscub thadscub is offline
Default K301AS engine rebuild
Hi guys:
I'm getting ready to start rebuilding a k301as out of a 123. Other than removing balance gear and governor gear, anything else I should replace
Thanks Thad
Old 04-05-2018, 06:18 PM
You're not removing the governor gear are you?
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 04-05-2018, 06:26 PM
I think he means he’s replacing the governor gear? Maybe with a steel one?
Old 04-05-2018, 06:34 PM
Maybe but I'm just making sure.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 04-05-2018, 06:59 PM
dodge trucker dodge trucker is offline
He says"gear" not "gears" most that have balance gears have 2 of them I haven't seen this but have read where some have 3 balance gears... (Mostly 16hp I think)
You certainly want to pull both balance gears and leave them both out. Maybe he doesn't know that the governor gear is " across the cam" from the balance gears?
Old 04-05-2018, 07:03 PM
Originally Posted by thadscub View Post
Hi guys:
Thanks Thad
I'd leave the governor gear in. If you want to replace it, that's a good idea.... but it kind of needs it.
You should replace:
Piston (and rings)
Connecting rod
Valves
Bore it
Grind the crank
Grind the valve seats
Bead blast and plane the head
And obviously, all gaskets and seals
Replace as needed:
Valve guides
Check the camshaft
Rework the lifters and adjuster bolts as necessary
Governor gear
Governor control rod bushing
Check the arm on the governor control rod. Weld it if needed.
Remove the balance gears and chuck them in the scrap.
Old 04-05-2018, 07:35 PM
thadscub's Avatar
yes i mean the governor gear will get replaces with a new one and balance gears will be removed
Old 04-05-2018, 08:16 PM
Great. I wasn't sure what you meant by the way you posted your comments.
Old 04-08-2018, 06:52 AM
Poser Poser is offline
This will be very helpful for me in the future, thanks again!
It's good to see what really needs to be done.
Kevin
