Does this round black piece that is frayed (I don't know what it is called) need to be replaced or is it ok? What is it called and what is it for?
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart ![]() ![]() ![]() ![]() ![]() ![]() |
Rag Joint
Yup! |
It is called a flex disk and yes it needs replacing! While you have it apart check the couplers for wear. When they are loose and sloppy they create unwanted vibration and possibly a safety hazard! Easy to replace and the parts are available from Cub Cadet and sponsors like Jeffin PA.
![]() Queen Of The Quietlines! ![]() |
Does anyone know the part number for it?
IH-376257-R3.
cubcadet.com is easy to use!
![]() Quote:
![]() There are two different Flex Discs for Cub Cadet Tractors. It depends on your model.
It is a 149 so I guess it would be IH-376257-R3. Thanks for telling me that.
What they said, also I would like to add if you let me, clean up the crud, power wash or what not the area around the pump and run it before you fix the driveshaft to see where the leak is coming from. Then you can fix the leak while you have it apart. It may be the seal where the coupler attaches to the pump shaft is, or the lines may be leaking, or the release valves may be leaking or the the cork gasket too!
![]() Quote:
You don't get oil soaked dirt without oil from somewhere.....
