Wanted everything needed to install sleeve hitch on a 1650 with hydraulic lift. Must be willing to ship to U.S address and a bill of sale because I will have to pay tax when coming back into Canada.Thanks also a rototiller and gear box if available.
There are two different styles that could be on your tractor. Serial number 616145 and below uses the shaft style. Above that uses the bolt style.
Doug Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift 1250 w/hydraulic lift, lights,weights, spring assist. 50C deck converted to an A with front wheels 44C deck converted to an A with front wheels. QA-36A 42" blade |
Well that’s sure good to know there’s a difference. So mine would be a shaft style. Know what is difference between the 2 sorry I’m learning.
If there are 2 bushings spun welded to the inside of the top of the frame rails in the back, then you have the type that takes only a piece of round rod w/holes for cotter keys.
If there are no bushings, then you need the Frankenstien bolts to mount it |
Ok thanks. I will need to have a look to make sure. 👍
Ok I have found sleeve hitch parts thanks. Now just looking for reasonably priced tiller gearbox and bracket.
Do you have a tiller?
Yes I have tiller.
There is a gearbox in the for sale section....
Yes I seen it but a little to much for me. Nice unit but by the time I transfer from Canadian to US dollars plus shipping I could almost buy another tractor🙄 looking at 400 Canadian dollars
