Old 02-25-2018, 10:28 PM
wayne13 wayne13 is offline
Default Tiller lift?
I took the tiller lift off a 149 my question is about the shaft that goes through the frame of the tractor and the two bushings that are on the rear of the frame do the bushings come off the frame or are they welded on?
Old 02-25-2018, 10:30 PM
Grab a hold of them.... did they come off in your hand?
http://www.cubcadet.com/equipment/AR...0-A/0025400025
Old 02-25-2018, 10:37 PM
I used channel locks on them, no luck are they pressed in? or welded?
Old 02-25-2018, 10:38 PM
They are welded.
Even if they were pressed it, why would you want to take them out?
Old 02-25-2018, 10:52 PM
To use the lift on a different tractor. I have two 1450s that I looked at one has the bushings one does not? Can you buy the bushings for a tractor that doesn't have them? Would they have to be welded on?
Old 02-25-2018, 11:16 PM
No. A 1450 tractor (and newer) takes a different mount. You need a pair of "Frankenstein" bolts to mount the lift.
You can buy a set from Jeff:
http://www.onlycubcadets.net/forum/s...ad.php?t=20875
Old 02-26-2018, 10:37 AM
ironman's Avatar
ironman ironman is offline
I may be misunderstanding his question but I think he means these things.
the first picture is from the 149 parts manual, the second is from the 1250 manual. I don't know if the 1250's would be welded or pressed. I have a 1200 but it's not handy right now. The p/n for #20 below is 393 831 r1 and they refer to is as "washer".
