Thread Tools
Display Modes
The trunion bracket has the notorious wear notch on one end will weld that up to fix. How much slop or side to side play is tolerable on the sleeve hole on the damper plate. I can move it side to side about 1/8 inch. Does the damper plate need replaced or is okay.
Thanks, Tim |
You could replace it, but the shaft is probably worn, too. I'd just shim it like this:
