Old 02-23-2018, 04:05 PM
gt383mag's Avatar
gt383mag gt383mag is offline
Default 364 on a 2182
anyone here ever put a 364 blower on a 2182? by the parts lookup you could get one on a 982 and it shows 2 different pulley diameters for the front PTO so i would assume thats for the big and little engine side PTO pulleys and it also shows it using a 1/2 or 5/8 belt. the 1812 works it just fine but is tired and i like the way the 364 lifts like 8 inches off the ground the 450/1 only lift like 2 inches maybe
Old 02-23-2018, 09:25 PM
Can't put a 364 on a 2182. Yes it will mount, but it wasn't designed for that big PTO. The two pulleys are made for the QL and 82 series tractors. Plus, you will need the lowering brackets in the rear for it to work with the SGT. Better left off of it unless you change the PTO.
Old 02-23-2018, 11:28 PM
gt383mag's Avatar
J my 2182 is a early model dont that have the smaller pto pulley?
Old 02-24-2018, 12:27 AM
Well, I thought all the 2182's came out with the larger PTO..... but there does appear to be a SN break.
Seriously though.... go look at it. You don't know what size PTO pulley it has? Take you about 2 seconds to see if it's a 4.5" or 6".
Old 02-24-2018, 07:18 AM
Early 2182's had the small PTO.
