Old 02-21-2018, 02:49 PM
kbrothers kbrothers is offline
Question 2082 Starter Removal
Haven't messed with my Cubs for awhile What is the procedure to remove the starter on a Mag 20? Do I need to remove the starter bolts to get the starter from between the two engine mount ears/lugs??
TIA for suggestions Ken in PA
Old 02-21-2018, 03:00 PM
Terry C's Avatar
Terry C Terry C is offline
Originally Posted by kbrothers View Post
Haven't messed with my Cubs for awhile What is the procedure to remove the starter on a Mag 20? Do I need to remove the starter bolts to get the starter from between the two engine mount ears/lugs?? TIA for suggestions Ken in Pa
Easier to remove engine. Also you can clean out fins and flywheel area at the same time. I’ve done it in the tractor but was tight.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 02-21-2018, 04:36 PM
Well... the starter bolts definitely have to come off before it can be removed from the mounting ears... so yes.
Terry is correct.... remove the engine to change the starter. It's not too fussy.
