Has anyone on here used the cub yellow and white from napa and have good results?
Anytime I had a Cub painted NAPA paint was used. The 2 Originals in my album were done with NAPA paint. Painter expressed how nice the paint was to work with. I don't recall what reducer etc. was used.
These are the color chips and numbers at my local Napa
That is neat, thanks for showing, maybe one day.
Kevin |
I used Napa’s paint on one of my originals. Martin Senior I think is what brand it was. They mixed it with reducer for me so it was ready to spray after I added hardener. I had always mixed my paint myself so it seemed a lot more reduced than what I was used to but after some gun adjustments I had it flowing good with no more runs. Came out well.
I believe like Alvy said.. Napa paint is made by Martin Senoir.. I have never used Napa but I have had good luck before with Martin Senoir paint.. Good luck with your project!
Jay 40 years of Using and playing with IH Cub Cadets! Proud owner of the following: Cub Farmall, Super A Farmall, Original, (2)70's, 72, 100, 102, 123, 105, 125, 127, 108, 128, 1450, (3)782's, Yellow 982, 1782, "Sam's" 2182, M Farmall and a #7 trailer |
Alvy do you remember the adjustments
Well not that I’m a painter let’s get that out of the way. But, at first, the paint was running like mad so I think I kept the same psi but adjusted the knob that controls how much paint it puts into the gun when you squeeze the trigger (material knob maybe??) amd also made the spray pattern a bit wider.
Tim aka Olds is the guy to ask for advice but I just did a lot of trial and error on cardboard when I used that paint. Again, it was premixed by them so it’s possible that they even mixed it wrong but it was super thin and watery so I had to do a lot of thin coats but turned out ok. PS I use the harbor freight gun that most here use and it does a good job
