Old 01-21-2018, 08:38 PM
Default 48" mower opinions
Found a 48" mower for sale that I have questions about, in relation to a QA mower of the same size. It looks like it's a pin on deck- how difficult is it to convert it to a QA? Is the front cast piece the same between the two? Do the deck hangers interchange somewhat easily? Also, I see it's missing the belt shields (no problem, I have parts on a QA mower) can those be bolted up without making new holes in either the deck or the shields? It looks like it hasn't been used too much as the baffles are still in tact on the underside. I've never seen a guard like what's on the discharge side. Are there plates added to the frontside of the deck? Not sure what those are. Having not seen it in person I'm searching some opinions and knowledge before making a trip and being disappointed in buying something wrong.
Thanks
Old 01-21-2018, 08:52 PM
Daniel,
you will need a qa mounted up front,then hang the mule drive on it that is shown in your pics, or find the bolt on mule drive the type that is on a 122 and mount it that way.
Look in the cpe2 manual for mower decks it will help you out.
Old 01-21-2018, 09:08 PM
Hmmm...so it isn't as easy as unbolting the pin on mount brackets and triangular cast piece (from the mower pictured) and bolting on said brackets and cast piece from a QA mower?- granted I have the subframe/mule drive for a QA mower already. Sorry I looked at the manual you stated, but trying to get clarification.
Old 01-21-2018, 09:16 PM
http://www.onlycubcadets.net/forum/s...ad.php?t=24721
If you take the center section out with the pickle fork on it and transfer it over to your other mule drive it should work that way I know the cast iron piece will not work because it's shaped differently .
Old 01-21-2018, 09:45 PM
Thanks. This is a bit more involved than I’d like to put in it so I’m probably going to pass on it. I appreciate the info master Lew.
Old 01-22-2018, 09:16 AM
Wait— do the pin on pieces on the cast triangle piece unbolt? Could I bolt up the hangars from the qa piece? (Or is the geometry still off- is the pin on subframe a different width than a qa subframe?
Old 01-22-2018, 09:50 AM
In the cpe link I added shows what you need to mount that deck on page 11 and page 14 shows you the parts for the deck you are looking to buy.
Old 01-22-2018, 07:13 PM
Sorry if I'm being a pain in the *** and I was just trying to ask as many questions as I could to help understand it better before I regretted making a decision. Thank you for your patience and understanding.
Old 01-22-2018, 07:33 PM
No problem!
Sometimes this deck stuff reads like setting up old Hi Fi equipment.
