Old 06-26-2010, 12:46 AM
mrlightrail mrlightrail is offline
Default 1450 overheats.
Got a 1450 with a 14hp Kohler. After running for about 15 min, the engine loses power. When I cut the PTO, and bring it down to idle, it runs fine, engage the PTO, and try to mow again, it lugs out again within a minute.
Any suggestions?
Old 06-26-2010, 01:22 AM
CMA's129's Avatar
CMA's129 CMA's129 is offline
I bought a 12 hp that did that. Head was warped, gasket blown, and it was out of time. I think the timing was the initial problem and the PO let it go until the head warped. Check for mouse nests in the engine too.
"Good Dogs Never Live Long Enough!" Casey Angeletti
Old 06-26-2010, 02:11 AM
Old 06-26-2010, 07:00 AM
Welcome to our Forum....
Your title states "Overheats" yet your description makes no mention of it. With that in mind, could be a Fuel Delivery problem, ie: Carb, plugged vent cap, dirt in the tank, etc.
Old 06-28-2010, 04:53 PM
cub1200puller's Avatar
cub1200puller cub1200puller is offline
My 1650 done the same thing last weekend. It would run fine untill the blades where turned on and then the motor would bog down. Turned out to be the points had loosened up and there was barely any gap between them. Reset the gap to .020" and everything was fine.
