Old 01-16-2018, 02:30 PM
GERKS 149 GERKS 149 is offline
Default Carburetor rebuild kit
I have looked in the Cub parts lookup and some vendors, but I am unsure of the correct carb rebuild kit. Looks like the Cub parts says to use the 25 757 02 for the Quietline series regardless of carb size 26 or 30. Then it looks like you use the 25 757 01 for the 109-169. I always thought that you use the 01 kit for the #26 carbs and the #30 use the 02 kit. I have a 109, 1250, 1450 and 149. Any clarification would be appreciated
Old 01-16-2018, 02:49 PM
According to the Kohler Condensed Parts Guide:
25-757-01-S is for 8 to 14 HP K & M series Engines with Kohler Carb
25-757-02-S is for 14 to 20 HP K & M Engines with Kohler Carb
Looks like the 14 HP K321 or M-14 could go either way. I would suggest using the correct Kit as the Parts Manual suggests.
Old 01-16-2018, 05:11 PM
Workingstiff Workingstiff is offline
Kohler has there own carb? Mine is a '77 1200 with a Walboro on it. Are there different kits for Walboro carbs? Hope this doesn't offend OP.
'76 1200 Dad bought
'75 1200 "Twinsie" per my daughter
Old 01-16-2018, 05:33 PM
Why...yes they did. From the 1963 into the late 1980's.
Old 01-16-2018, 07:12 PM
Well.....kind of. The Kohler carburetors were made by Carter. Just badged as Kohler. They all take the same kit if they are an adjustable carb.
Old 01-17-2018, 09:32 PM
Thank you Gentlemen
'76 1200 Dad bought
Old 01-17-2018, 11:32 PM
Does a one know the difference between these 2 kits! The only thing I see is the brass piece has a different end on it
Old 01-18-2018, 05:41 AM
The difference is in whether it fits a #26 or #30 Carb.
Old 01-26-2018, 10:22 PM
I have both rebuild kits so I’ll be careful to look at what is already in it. I am under the impression that the #30’s take the 02 kit. Thanks for the help
