Old 12-26-2017, 01:20 PM
Workingstiff Workingstiff is offline
Default Looking for a link,plz
Hi,
I'm new here but not to Cub Cadet. I have our 1200 I grew up with. New long block 15+ yrs ago. New front tires last fall and re-built steering box.
I was flipping thru the posts and ran a across a link that if you put your model# in it shows what attachments or implements. You can run.
Thanks Dan
Old 12-26-2017, 01:29 PM
This is the list of attachments listed on the Cub Cadet site for a 1200
*Attachments
190-364-100 45" Snowthrower (IH Design)
190-364-100 Two Stage 45" Blower Frame
220 32" Lawn Sweeper, 190-220-100
222 38" Lawn Sweeper, 190-222-100
368 10 Cu. Ft. HD Utility Cart, 190-368-100, 190-368A100, 190-368B100
38" 3 Spindle Mower
38" Deck Quick Attach
38", 42" 3 Spindle Mower
40" Box Scraper
42", 54" Push Blade - 2
425/425A 17 Cu. Ft. Utility Cart
438 Broadcast Spreader
44A 44", 50A 50" 3 Blade Deck
521 Utility Cart
653/653A 10 Cu. Ft. Utility Cart
H42 Snowthrower Gearbox and Mounting
H42/H48 Snowthrower Electric Chute Control
Haben Snowthrowers H42, H48, H48, H42, 353, 354
Helper Spring SE # over 400,001
QA36A, QA42A Snowthrowers
Tiller #1 and #1A Front Drive
Tiller #2, 2B
Tiller #2B, Front Hanger
Trailer #2 Built 1971 - 1982
Trailer #4 Built 1976 - 1982
Old 12-26-2017, 02:17 PM
Ok Thanks that was fast!
Old 12-26-2017, 03:27 PM
The actual link is a Cub Cadet site. You simply plug in your model and a PopUp menu appears, then look at "attachments". See.... http://www.cubcadet.com/equipment/cubcadet/service-and-parts
Old 12-26-2017, 04:32 PM
Great Thanks. I saved it.
Old 12-26-2017, 04:38 PM
That's why OCC is the best Cub forum.
Old 12-27-2017, 07:26 AM
Leadslingingdaddy's Avatar
Yep I would rate that answer as a 10.... and only took one reply.... imagine that...
Old 12-27-2017, 06:53 PM
Yep, great guys, great info,great cubs
'76 1200 Dad bought
'75 1200 "Twinsie" per my daughter
