View Poll Results: What color should the wheels be?
White Wheels 36 81.82%
Red Wheels 8 18.18%
Voters: 44. You may not vote on this poll
Old 12-23-2017, 10:58 AM
cadetmike's Avatar
cadetmike cadetmike is offline
Default Winter Project 122
I have decided to start a thread to keep everyone updated with my winter project. I plan on making several modifications to my 122 as well as making some repairs where needed.
- V-twin swap (need to get an engine yet)
- drop and lengthen front frame section (for engine fitment)
- fabricate an new front axle complete with 4-bolt trailer hubs (cast axel is
shot, holes are all wollowed out)
- repair shift forks (done)
- possibly install 26" tires on the rear
- repaint in red IH color scheme
I am not completely sold on the rear tire swap, I have not seen many 122's with 26" rear tires, but I like the idea, so I need someone to convince me one way or the other. I also love the idea of creeper gears but they are hard to come by and not cheap (from what I have seen) here are a few pics of the project so far. I also included some of my custom sleeve hitch.
Old 12-23-2017, 12:39 PM
cadetmike's Avatar
It seems I have been persuaded to rebuild the k301 I have, rather than do the v-twin swap. that being said, I do love a good rebuild!
Also I think I will keep the 23" tires I have already on it and maybe peruse running dual's when not plowing.
Old 12-23-2017, 04:56 PM
johncub7172's Avatar
cadetmike Thanks for the pictures! Looks like a good functional rear lift. Nice to see the "before" pictures!
Old 12-23-2017, 08:15 PM
While a creeper gear works great with a tiller , they are a weak link in the powertrain.
Jeff
Old 12-23-2017, 08:43 PM
cadetmike's Avatar
thanks, i had some pics of before i tore it apart but i can not find them
Old 12-23-2017, 08:44 PM
cadetmike's Avatar
Jeff
I sort thought it might be... thanks for the insight
Old 12-23-2017, 08:50 PM
Do be afraid to ask questions, BS answers are not allowed here.
Now if do decide to use one and you wear the spirol pin hole, I can weld it up and cut new snap ring grooves to save it.
I can make parts if you need them too.
Some of the parts I make are here http://www.onlycubcadets.net/forum/s...ad.php?t=20875
Old 12-23-2017, 09:54 PM
cadetmike's Avatar
Looks like you make some quality parts there, i will keep you in mind
Old 12-23-2017, 10:12 PM
cadetmike's Avatar
tore the front axle out and had a good look at it, pivot pin was rusted fast in the axle, had to cut it free of the frame then press it out of the beam
looks like I will need to drill out the spindle holes to 7/8 and install bushings, then I think I will build WF style spindles as they are stronger, with 1" shafts to take 4 bolt trailer hubs... sounds like a lot of work but I hate sloppy steering and such. And why didn't they ever put a grease fitting in the beam for that center piviot?
Old 12-23-2017, 10:25 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
Early production did not have grease zerks for the axle kingpin. Last spring I had two 102's in my shop...one was a 1965 with no grease zerk and the weird brake pedal. The other was a last 1967 that had the zerk, different pedal and a serial number tag on the back side of the transmission.
If you want to avoid the sloppy draglink issue and want stronger spindles, put a wide frame axle with 1" spindles and you will be satisfied. Bolt on hubs look cool but are overkill. Have fun with your toy!
Queen Of The Quietlines!
