Got these delivered today. Pricey but meaty. We'll see how they work.
Doug Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift 1250 w/hydraulic lift, lights,weights, spring assist. 50C deck converted to an A with front wheels 44C deck converted to an A with front wheels. QA-36A 42" blade |
Who did you get those from?
snowblowerskids.com.
Looks just like the ones I make from old spring leaves
Hopefully you won't have to use them!
Put those on last year—-night and day difference ! Somehow ended up ordering mine through Home Depot. Best solution I have found for throwing snow on gravel driveway.TIP ... lift thrower when turning ( even slightly ) on gravel.
On the web site he does say he sells through Home Depot.
I didn't see the QA36 or QA42 on the list at this web site. Which one did you order?
You have to go by the bolt spacing which is 3 1/2". I got the Pro series with the 1/2" thick runners. Part number PRO3575-A.
