Old 06-21-2010, 11:07 PM
tukn20s tukn20s is offline
Default Help with sleeve hitch information/specs
Sorry if this is posted somewhere, but I did a search and didn't have much luck.
I picked up a sleeve hitch and and brinly style adapter from a guy that used to make these. Anyways, the pieces I have, are all bent and welded, but none of the holes are drilled. This is my first hitch so i'm not sure on everything. I aplologize if i'm using the wrong terms for some of the pieces.
I am looking for the following information:
-Hole diameter for the tube in the U-adapter that pin goes through to attach the implement
-The size and spacing of the 2 adjuster bolts
-hole diameter in the lift pin (upper lift straps attach to)
-average length of the lift straps
Any help will be greatly appreciated. Thanks.
Old 06-22-2010, 12:09 AM
Butterbean's Avatar
Butterbean Butterbean is offline
http://www.onlycubcadets.net/forum/s...ighlight=plans
Check out this thread. Should answer all your questions
Charles Rodgers
Clinton, MS
1971 Cub Cadet 126
Serial # 382463
Old 06-22-2010, 10:52 PM
That was what I needed. Thanks!!!
Is there anywhere to find the specs on the lift bar for a 682?
