Old 12-14-2017, 10:37 PM
rocker582special's Avatar
rocker582special rocker582special is offline
Default Snowthrower question
Will a QA-36A snowthrower fit an 82 series cub cadet? I have a chance to get one sure cheap in very good shape. Just curious if it will fit my 582 Special or my 1811? Thank you for your help.
Rocky
Cub cadet 70,123(parts),125,582Special
Old 12-14-2017, 11:23 PM
It will fit but at minimum you will need to switch the pulley to 5/8" wide.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 12-15-2017, 12:04 AM
Three things need to be done.
* Change the Drive Pulley
* Change the Drive Belt
* Change the Upper Link to the Mount.
Old 12-15-2017, 06:14 AM
Cool thank you everyone.
Rocky
Old 12-15-2017, 09:05 AM
Just curious who sells these parts Roland? Thank you for the part numbers by the way.
Rocky
Old 12-15-2017, 09:54 AM
yettrbomb yettrbomb is offline
I believe xtreme motorworks sells the links. One thing to think about is getting the extensions that xtreme has to make the 36” take a bigger bite. Or make your own. 36” is narrower than the tractor and you can find yourself in a bad spot.
Old 12-15-2017, 01:14 PM
dodge trucker dodge trucker is offline
Saying this trying to be funny, doubtful it would work on account of the distance, but he could solve the"too narrow for the tractor" and need to extend part of the issue by buying my QA 42a.... Just n idea.....
Old 12-15-2017, 01:15 PM
The Belt is available numerous places.
The Pulley is still available from Cub Cadet.
The upper link is NLA from CC. Find a used pair or xtreme motor works has them.
Old 12-15-2017, 03:33 PM
I'm not so sure you need the upper links, I mounted a QA42A on my 782 and it lift 3.5" off the ground with the straight links and chute doesn't come anywhere near the hood.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 01-23-2018, 10:00 PM
rikers74's Avatar
rikers74 rikers74 is offline
Default Owner's Manual
Does anyone have or know where I can get a pdf owner's manual for a QA42A?
