My tiller stopped spinning yesterday.
![]() Anyone have any manuals I should get to rebuild this thing? Any one have an extra one they want to sell? |
If its locked up check and see if thier is something stuck underneith in one of the tines. My #2 tiller got an old horseshoe in it and killed the motor.
You may try the Manuals in our Technical Library Section.... Manuals
checked that. Nothing stuck.
Belt to tiller itself. It was slipping at the tiller end. When I took tension off the belt the tiller wheel was hard to spin.
Internal chain. 2a did that to me... Pulled the bottom bearings... Both wore out completly, moved the shaft forward... Turned fine. I bet it's a chain. Try going backwards...
Tyler Chiliak. Southeast Alberta Canada. My dad and I own, 1650, , 1450, 1250, 1250, 1200, 982, 782, 149, 149, 149, 128, 128, 123, 100, 100. Also a 1310, 1500, and 2 1600 IHC trucks. |
Thanks for the view. I hope I can still get the bearings if that is the problem. I will take a look at it when I get back from California.
I will take a look at the chain first thing. Then decide while I have it open what else will need to be replaced. Anyone have the part numbers on the bearings if I need them?
I would just take the old bearings to a bearing supply place like Motion Industries to procure suitable replacements. You might also want to replace the chain while you're in there if the links don't move freely, and anything else that looks badly worn.
