Old 12-04-2017, 02:09 PM
Terry C's Avatar
Terry C Terry C is offline
Default Hydraulic experts needed
Hi all,
I’m starting the process of a hydraulic powered rear sickle mower.
Would also like this pump to run a log splitter if possible. So if someone could recommend a pump and motor for this application or direct me to somebody’s
website that has the charts or whatever to help decide.
Pump to be mounted under the front PTO and tank to be placed wherever I need it to.
Just need a place to get started, cause I have no skills in the world of hydrolics.
I have every other tool needed for the fabrication. (CNC mills,lathes, waterjet)
Thanks
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 12-04-2017, 05:53 PM
spudder spudder is offline
Terry, go to "My Tractor Forum" and scroll down through the sub forums until you get to the "hydraulics" section. There are several people who can help you. Post a thread with your questions.... I'm sure you will get lots of help. There is a man that goes by "Tudor" who has a wealth of knowledge regarding most anything related to hydraulics.
I bought a 1864, it's just grown from there. The Cubs have replaced old Chevys as my hobby/passion. The only car I have left is a '67 Chevelle wagon.
Seems like a good trade off. I can put five Cubs where one car sat and there are no titles or license to fool with!
Old 12-04-2017, 08:21 PM
What he said just be patent with all of the ad's on MTF
Old 12-04-2017, 08:38 PM
Ad blocker helps, no more ads for me.
Up to 534 and counting...
Old 12-04-2017, 08:48 PM
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 12-04-2017, 08:51 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
I would be glad to figure it out WITH you, but take the Intelligent masses opinion of MTF or WTF or WGAF... either way Im sure they are way more intelligent than any one here, just ask anyone here...
1- 1200 in pieces
1- 1864 in pieces
Old 12-04-2017, 09:55 PM
Terry C's Avatar
Just the man I was looking for!
I was hoping for a learning experience from this.
My only thought so far is that the log splitter would drive the train on the pump choice cause the sickle mower can’t take much power to run( at least that’s what I think based on the fact I used to mow hay with a IH C that had a 9ft? bar.
Terry
3225
Old 12-04-2017, 10:00 PM
Terry C's Avatar
As soon as it’s light out tomorrow, I will snap pics of the sickle mower. It’s a mid mount Haban (I don’t know the number) that’s going to be made into a rear mount and attached to a 782 or my other 2182. Hence not wanting to use rear PTO. Plus it will be unique being hydro run.
Terry
3225
Old 12-05-2017, 11:20 AM
Terry C's Avatar
Here is the mower. I see it’s a 402. Going to be a lot of brackets I’m not going to use.
File Type: jpg 1050DDF9-62A9-4CC9-9DC7-FE455EE082AB.jpg (25.9 KB, 202 views)
Terry
3225
Old 12-05-2017, 08:26 PM
Rescue11's Avatar
Well I've basically got a hydraulic PTO figured out that Im hoping to incorporate into the design of my three point hitch. But the components should work with your sickle mower as well! Just got home, I'll have to dig through my notes.
1- 1200 in pieces
1- 1864 in pieces
