Old 11-21-2017, 11:55 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Default 782 Command re power.. CH20 or CH18?
Hey Guys,
I have a lead on two different engines.. I want to do a repower on one of my IH built 782's at some point in the future..
Looking for tips, tricks and what parts I should grab
The first engine is from a 2084.. what parts should I grab that I may need.. I know I will need the complete engine, mounting plate, clutch and muffler/shields etc.. I can get other parts from the tractor... just not the whole unit..
The second engine is from an 1864.. same deal... what parts should I get?
Is either engine better than the other for the repower?
Any tips, or suggestions appreciated... Ive never dug into the repower side of things.
I like the old opposed twins but I have two tired ones and have a chance at either one of these commands at a good price.
Thanks in advance!
Jay
Proud owner of the following:
Old 11-22-2017, 06:55 AM
Mcamp Mcamp is offline
The 2082 would have a 20hp magnum engine if it is orig.
Old 11-22-2017, 08:43 AM
guyina4x4's Avatar
guyina4x4 guyina4x4 is offline
I have both a CH18 and CH20, they are exactly the same engine, at least from what I can determne.
the only difference is the carbureter.
I really like them both, they are super easy to work on.
my CH18 has over 1000 hours on it, hour meter stopped at 915
the CH20 has around 1300 on the clock
they both needed some new oil seals and good cleaning of the colling fins but both run great.
JD x475
Old 11-22-2017, 08:54 AM
Terry C's Avatar
Terry C Terry C is offline
Originally Posted by jaynjeep View Post
Hey Guys,
The first engine is from a 2082.. what parts should I grab that I may need.. I know I will need the complete engine, mounting plate, clutch and muffler/shields etc.. I can get other parts from the tractor... just not the whole unit..
Thanks in advance!
It’s a toss up. Go for the least hours? Whichever one looks like it got better care?
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 11-22-2017, 09:00 AM
Rescue11's Avatar
Rescue11 Rescue11 is offline
What Terry said. And you will want to do the driveshaft mod too.
1- 1200 in pieces
1- 1864 in pieces
Old 11-22-2017, 09:02 AM
jaynjeep's Avatar
Misprint on my part.. the 2082 is actually a 2084
Thanks for catching my mistake
Jay
Old 11-22-2017, 09:37 AM
mickb72 mickb72 is offline
Buy'em both, you said you had two tired ones. I know the pullers put the 18 heads on the 25's for more compression. Mike
Old 11-22-2017, 09:45 AM
Pretty sure they use the same head. Not sure how that would help. If they are different, show me in the parts book.
Old 11-22-2017, 10:14 AM
jaynjeep's Avatar
I have really thought hard about getting them both.. the CH18 is almost new.. has 100 hours on it... it's not cheap..
The CH20 is a higher hour engine... but a lot cheaper..
Both are supposed to be complete just as they were pulled out with PTO, muffler, muffler shields etc..
Waiting on pictures of the engines now
Jay
Old 11-22-2017, 11:15 AM
DieselDoctor's Avatar
Ditto on getting the low hours engine if you can only get one. If you truly believe that you will repower your other tired Cub at some point in the future, get both. Who knows if a good deal will come around again when you need it. You'll kick yourself at some point if you don't. There! Feel better Jay?
