Old 11-21-2017, 06:57 PM
yamachuck yamachuck is offline
Default QA42 right angle gear box
hello everyone my qa42 blower gear box has the sealed unit[ no filler hole...when I bought the blower I took off the cover cleaned and filled with 80 weight ..that was 4 seasons ago ..appears no leakage would you take it off and service..your thoughts please .
Old 11-21-2017, 07:39 PM
How much has it been used in 4 season's? If it was anything like here then it barely made it out of the shed. If you are sure it hasn't leaked then its probably fine.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 11-21-2017, 08:14 PM
Really supposed to have a thin grease in it, not oil. You really should probably at least check the level.
Old 11-21-2017, 11:00 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
To be safe Jon is right, I've never heard of a gear box that ran better dry... Literally takes minutes to check, better than hours of down time!
1- 1200 in pieces
1- 1864 in pieces
Old 11-22-2017, 12:52 PM
ironman's Avatar
ironman ironman is offline
I don't have any pictures but when I had mine apart to clean and check out, I determined a good spot to drill and tap a hole to put a 1/4 x 28 grease zerk. A pump or two every season beats the heck out of wondering about it or taking it all apart to take a look.
Old 11-22-2017, 12:59 PM
But the box doesn't take grease either.... unless you are using John Deere corn head grease. (Which is actually the same lubricant IH recommended, just an IH brand.) 1 or 2 pumps of grease isn't even a tablespoon of lube. Not really enough to make a dent in the capacity of the gearbox.
Old 11-22-2017, 03:21 PM
so jmech this corn grease .can I take the cover off with snowblower on tractor and fill the cavity with corn grease or will the grease fall out thanks
Old 11-22-2017, 08:02 PM
Sure you can. Drain out the oil you put in it though.
OK, so I AM NOT pushing Deere lubricant, but here goes:
People don't seem to want to go to the trouble of mixing up their own lube for the box. I do it that way because I keep wheel bearing grease and gear lube on my shelf, so I just have to mix some up when I need it. You can get lube from CCC but other people have said they want some ridiculous amount for it. (Like I think I heard $30.) Deere corn head grease is the same stuff. It's a 0 grade grease. You can buy it in a grease gun tube, but they may sell it in other packaging. (*Note to ironman below.*) If you purchase it, take your grease gun apart and remove the tube of grease you have in it. Install the corn head grease tube in it, but don't put the handle back on the gun. Aim the tube at the gearbox and release the tube, BUT HOLD ON TO IT!! Let it push out what you need, then pull the rod back. Remove the tube and put it on the shelf. You can cover the end with (Reynolds) plastic wrap from your wifes kitchen drawer. Then you can reinstall your old grease tube.
You can get the grease from Deere, or from here. Not bad on price. If you don't want the Deere lube, then you want to buy grade 0 grease, or do what I do and make your own. Here is a video of the Deere stuff, just so you can see how it keeps the gears lubed. Regular grease will fling away and not flow back to the gears. Again, not pushing the JD stuff, just using it as an example.
https://www.youtube.com/watch?v=7zNhli-J0Gk
ironman:
I just wanted to point out that if you are using this type of grease then adding some with your gun through the zerk you added would be fine. But if it isn't leaking out, not really necessary to do.
Old 11-22-2017, 08:45 PM
Iron man, a little brill creme goes a long way in the gear box, just a little dab'll do ya!
Up to 534 and counting...
Old 11-23-2017, 09:28 AM
thanks jmech so if I were to mix my own.like you I have gear lube and bearing grease on hand.just mix the two parts so thick enough to pack the gearbox housing thanks again for info
