Old 10-31-2017, 09:56 PM
fieldman12 fieldman12 is offline
Default 1650 Kohler K341
I am wanting to check my timing since I have a new condenser and points I installed. According to everything I have read there should be an S or SP to look for on the fly wheel. I have spun the fly wheel many times and all I see is a straight line. I assume this is TDC?? I have timed stuff before but its been many years. Is it correct I should find an S or SP? I am wanting to know from someone who has done a 1650 specifically. The gap I have read should be .020
Old 11-01-2017, 12:05 AM
dale c. dale c. is offline
there are 2 marks s is the timing mark and t is top dead center , with engine idling take a straight screw driver and rub the flywheel to shine it up it should make the marks visible the mark the s mark with a small paint brush with white or yellow paint
Old 11-01-2017, 12:40 AM
Dale C gave good advice.
I will ad, when you set the timing statically, there will be NO GAP. You set the points to just break contact when the "S" mark comes in line. Forget the gap. Forget you read about a gap. Don't check the gap. Just set the ignition timing and forget there is a gap.
http://www.onlycubcadets.net/forum/s...ad.php?t=33461
