I think I've located a 126 parts tractor that has a creeper gear. Will the creeper gear fit into a 128 using all the same parts?
a 128 is a wide frame and the 126 is a NF
Drive shaft for the 126 is #IH-385982-R91 The 128 driveshaft is #IH-545492-R91 I do not know the difference but there should be a mark on the 128 driveshaft where it would need to be cut as well as hole already drilled for the coupler were you to do as planned, using the 128 DS I'd restore the 126 if it were me as it is the 3rd rarest cub. If you do the swap and plan on keeping the 126, it will then need a new DS. |
The driveshaft is longer and the handle on the cweeper will have to be bent to fit the 128 slot hole thingy on the the tunnel cover.
