Old 10-28-2017, 06:26 PM
Default Center mower deck spindle loose
Looking for advice on tightening up the center spindle on my triangular 48" mower... I know it's more than just the pulley as the pulley is loose, and the blade is loose underneath as well.
I've never worked on a spindle so this is unfamiliar territory (although I understand how to tighten bearings on axles, etc) - advice? Tips?
Thanks
Old 10-28-2017, 06:34 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
The bearings, spindle or both are probably badly worn. Take it apart and clean the assembly. The problem will be obvious. You do need the proper spacers in order to maintain the correct bearing preload when you tighten the nut.
Queen Of The Quietlines!
Old 10-28-2017, 07:48 PM
Is the pulley making a mark on the cast piece?
Up to 534 and counting...
Old 10-29-2017, 11:28 AM
No, not quite.
Old 10-29-2017, 11:51 AM
Time to rebuild it.
Old 10-29-2017, 04:09 PM
How involved is this? Not that I am questioning my mechanical ability; just trying to see what I'm getting into before I start work on it. What typically wears out on these? The bearings?
Thanks
Old 10-29-2017, 04:28 PM
Bearins. Cup, cone and seals. 2 of each.
Old 10-29-2017, 05:10 PM
Washers, spacers, also, and believe it or not the bottom of the pulley will wear.
Old 10-29-2017, 06:23 PM
CubDieselFan's Avatar
It may have the sealed bearings.
Old 10-29-2017, 06:26 PM
If it is the ones Jonathan stated, here are the Cub part numbers. * 921-3018A * 941-04298 * 741-3028 2 each
