Old 10-08-2017, 01:45 PM
Default 100 trans noise.
Here's a short video of the noise the 100 is making, it only does it in 2nd gear and it popped out of 2nd twice yesterday. I assume the popping out on gear is the detents but have no idea what could be making the noise, any ideas?
https://youtu.be/mmH3dF959DY
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-08-2017, 01:56 PM
I only hear the engine....
Now and again i think i can hear a snap, or click... like a gear trying to disengage, but not popping out. If that is what you hear, it likely has a chipped tooth.
Old 10-08-2017, 02:30 PM
Here's another video that you can hear it pretty good.
https://youtu.be/6juXs2KVZhk
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-08-2017, 02:35 PM
I put headphones on this time. Definitely hear it. Sounds like a chipped tooth. Only does it in second?
Old 10-08-2017, 02:44 PM
Yep, first and third sound fine.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-08-2017, 02:55 PM
Yeah. Chipped tooth on one of the two gears. Probably the sliding gear on top.
Old 10-08-2017, 03:11 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Sound like my washing machine!
I can't remember, did you do anything to the trans, other than paint and reseal it?
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 10-08-2017, 03:22 PM
Nope, just changed the fluid and painted it. I didn't hear the noise before or I would have fixed it then.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-08-2017, 05:58 PM
Merk Merk is offline
Do you know what tooth 2nd gear is? 16 or 19 tooth?
The early 100-70s had a 16 tooth 2nd gear. The gear sometimes breaks.
If my memory is working right serial number 898xx and lower has a 16 tooth 2nd gear.
Project Uncle Dick
Cub Cadet 70
Old 10-08-2017, 06:22 PM
No idea, I guess I will find out when I have the time to pull the rearend.
Pap's 100
Restored 108
1211 Dual Stick
1050
