Old 06-15-2010, 10:43 PM
tukn20s tukn20s is offline
Default 149 Hydro pump on a 682?
Does anyone know if a ported hydro pump off a 149 will fit on a 682?
Old 06-15-2010, 11:05 PM
jbollis's Avatar
jbollis jbollis is offline
Yes it will.
Sold everything but one.
Old 06-15-2010, 11:16 PM
Thank you very much! It should be a direct swap correct?
Old 06-15-2010, 11:22 PM
jbollis's Avatar
As far as I know, yes. All the pumps a pretty much the same. I have found ( in my hours on parts tree and in the service manuals ) there are some small difference. But those two should swap fairly easily. I have a thread going in the ccc section showing the disassembly of a hydro pump. After seeing what was in mine and finding out it is not as difficult as I thought, I would recommend doing the same. Disassemble,clean,replace seals,check bearings,and replace gaskets.
Old 06-15-2010, 11:31 PM
Thanks for all the help. I think i'm going to pick up the pump and maybe someday I will use it on the 682. I will definitely check out the disassembly thread.
