Old 09-10-2017, 08:19 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
Question Neighbor's 1872
My next door neighbor went on vacation for a few weeks. Came back home and his lawn needed mowing. He tried to start his 1872 but the battery was dead. He called me over since I have been involved with cub cadets too. We put a car starter/jumper on it and when he tried to start it, the engine rolled/turned over maybe 1/2 a turn to a full turn based on the number of compression strokes we heard, then just stopped. Repeated attempts to start only result with the solenoid clicking and no turning over. It is like the engine is stuck. The battery is fully charged on the charger now, and when you attempt to turn it over both the positive cable and the neg cables from the battery can get quite warm.
Ideas on what to tell him to check first and an easy way to see what happened? My first ideas are the starter and the gov cam gear. Not necessarily in that order.
I was thinking of trying to spin it over manually to see if I can do that or if the starter bendix has jammed up somehow.
Thanks....
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 09-10-2017, 08:24 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
Do you smell fuel? Could one or both of the cylinders be filled with gas from a leaking needle/seat? Check oil level to see if it over filled.
Queen Of The Quietlines!
Old 09-10-2017, 08:27 PM
DeltaCub's Avatar
Remove the spark plugs and try turning the engine over by hand. If fuel dribbles out then there is your answer.
Old 09-10-2017, 09:15 PM
FrankF3's Avatar
DeltaCub, thanks, good call. When I was over there, we did not smell fuel and the oil level was just below the full mark. When I see my neighbor in the morning, I'll pass this along to him. He should be able to test this out and pull the plugs. I'll report what he finds from this.
Old 09-10-2017, 10:36 PM
V30crewcab V30crewcab is offline
once you get past the possible fuel situation, start checking battery cable connections. grounds especially.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 09-11-2017, 07:48 AM
bleoh bleoh is offline
On my 1872 I have had the starter get jammed when the battery was low. Had to rock the crankshaft back and forth to un-jam it. I just put a socket on the PTO bolt.
Brian
Old 09-11-2017, 09:44 AM
jwalking's Avatar
jwalking jwalking is offline
Had the same problem with my 1872 after it sat awhile. Sure enough the fuel drained into the cylinders and crankcase. Pulled the plugs and pumped the fuel out and changed the oil. In addition to changing the needle and seat I added an inline fuel shutoff under the hood, just in case.
Old 09-11-2017, 11:40 PM
There already is a "shut off" on the bottom of the fuel tank.
Old 09-13-2017, 12:51 AM
FrankF3's Avatar
Thanks for all the things to look for. Next time I head over, I'll have a full bag of tricks to help him out with.
Old 09-13-2017, 08:13 AM
The shut off in the bottom of the tank requires removing the side panel to shut it off, when I had my 1811 I added an in line shut off right before the pump so all I had to do was open the hood.
Pap's 100
Restored 108
1211 Dual Stick
1050
