Old 09-04-2017, 07:27 PM
gscott gscott is offline
Default K161 Points Push Pin
I purchased a used K161 short block and need some help with the Points Push "pin" or "rod".
Does anyone know if a Push pin from a K241 will fit or is it the same part.
Or does anyone know the original part # for a K161?
Thanks
Old 09-04-2017, 08:24 PM
Well..... the 161 block and the 241 block are very different in size. The points push rod carries a different part number for the 161, and I'm about 99.999999% sure they are more than just different part numbers. Pretty sure the 241 rod is longer.
Go to Cub Cadet's website and look up the part number you seek. You can also look on Kohler engine site. No reason for us to do it for you....
Old 09-05-2017, 05:52 PM
Default K161 Push Pin
Thanks J-Mech.
Just getting into the Cubs. Recently got my first, a 71.
I appreciate the direction on where to look up info for these machines. Still learning what resources are out there.
Old 09-05-2017, 06:43 PM
Originally Posted by gscott View Post
Thanks J-Mech.
Cub Cadet still does carry a lot of the mechanical pieces for these old machines. Not all, but a lot. Some of the pieces no longer available can be found through aftermarket sources. There are members here on OCC that make a lot of parts.
Your 71 looks good! The rear rims are on backwards though...the dish should face out.
Old 09-06-2017, 08:35 PM
Default Wheels
Thanks.... I better get those wheels on right
Old 09-07-2017, 02:42 PM
Stephen.Mellish's Avatar
Stephen.Mellish Stephen.Mellish is offline
The Breaker rods are different between the k241/k301 and the k161/k181
The "in-spec" lengths of the pins are:
10-16hp is 1.500" to 1.600"
7-8 HP is 1.250" to 1.260"
The Collection, so far: Cub Cadet 100(x2), 125(x2), 123(x2), 70, 71. Adding more when I can find them.
