Old 08-25-2017, 07:41 AM
harvester850 harvester850 is offline
Default Analog Tachometer in an 82 series cub
I wanted to pass along my method of adding an analog tachometer to my 682. There are some Wheel Horse posts on connecting a tachometer to the alternator so I thought I would try it and it worked!
I purchased an Apex Tachometer from ebay:
http://www.ebay.com/itm/Electronic-C...72.m2749.l2649
Dip switches get set for alternator, 8 pulses / revolution.
I attached the signal wire to the right side of the tractor voltage regulator + lead. Power came from the hour meter power and grounded to the steering frame. Checked motor RPM with hand held tach and I am within a few rpm. Fit right into the hole for the hour meter. I moved my hour meter to the tunnel cover since the plug would reach and I don't need to monitor that constantly.
Hope this helps someone else try it.
Old 08-25-2017, 08:12 AM
I have wondered if you could run an alternator tach. Good to know it works!
Thanks for the post!
Old 08-25-2017, 08:33 AM
Thanks for the information and write up. Since the Quietline Series of tractors use the same Stator and V/R, I assuming it would work the same.
Old 08-25-2017, 09:30 AM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Cool! Great writeup!
How long did shipping from India take?
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 08-25-2017, 02:59 PM
The tachometer only took a few days to get to Northern OH from India. Much faster than the auction said. I had to email the seller to get the dip switch settings sheet.
Old 08-25-2017, 03:55 PM
Terry C's Avatar
Terry C Terry C is offline
Thanks for the write up! Looks great!
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 08-25-2017, 11:26 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Very neat and easy tach solution! Thanks for sharing with us!
Jay
Proud owner of the following:
Old 08-26-2017, 06:17 PM
Cool set up
Old 08-27-2017, 11:16 AM
Thanks Harvester, I just ordered one to see if it will work on my 982. I'll let you all know how long it takes to get here.
Old 08-28-2017, 11:13 AM
malchren's Avatar
malchren malchren is offline
since reading this write up I shall be ordering one as well for my 1650 and any other tractor that uses that alternator. I really appreciate the write up.
I think we all got yellow fever at this point.
