Old 06-14-2010, 12:58 PM
Butterbean's Avatar
Butterbean Butterbean is offline
Question Next project maybe
I have had my eye on this 147 for about 2 years.
I've been trying to talk the owner into either giving it to me or working out some kind of trade. He doesn't remember how long it has been sitting, but says it has to be close to 10 years. Yesterday, I talked him into selling it. He wants $150 for it. The only problem is I don't have $150 and I gave him $200 for this one about 2 years ago.
The 126 was running (after filing and setting the points) and I've been using it up until it "slung a rod" over a week ago.
It's really hard to justify the extra expense right now. What do you guys think. Is the 147 worth $150? I'll be thankful for any input.
Charles Rodgers
Clinton, MS
1971 Cub Cadet 126
Serial # 382463
Old 06-14-2010, 01:06 PM
It really sux about the money thing... Yes the 147 is worth way more than $150.00
Good luck to you.
Old 06-14-2010, 02:09 PM
dyt4000's Avatar
dyt4000 dyt4000 is offline
^what Sam said.
Co-Founder
You only need two things in life...duct tape and WD-40
If it's stuck and needs loosening, use the WD-40.
If it's loose and it's suppose to be stuck, use the duct tape.
Old 06-14-2010, 04:01 PM
Charles, the 147 is definitely worth more than $150. Hope you're able to get it.
Old 06-15-2010, 05:55 AM
Aroostook Aroostook is offline
Exclamation
For what it's worth, since you've dealt with this guy before and the 147's been sitting there for so long, wouldn't he let you pay for it a little at a time? Also, that left rear tire -- I'm used to seeing them flat on bottom. Is flat on top typical below the Mason-Dixon Line?
Old 06-15-2010, 07:27 AM
T-Mo's Avatar
T-Mo T-Mo is offline
I also agree - either he might let you pay for it over time, or maybe ask him to hold it until you can come up with the cash.
I would say on the left rear tire, it must have just been rolled to move it from an even brushier spot, therefore the flat spot on top. I hope you didn't disturb the snakes and field mice too much.
Old 06-15-2010, 08:20 AM
Butterbean's Avatar
Hopefully I can come up with the money by August. It probably won't be going anywhere before then.
If I remember correctly, when the picture was taken we had started pushing it and disturbed a wasp nest. It hasn't been moved since.
Charles Rodgers
Clinton, MS
1971 Cub Cadet 126
Serial # 382463
