Old 08-18-2017, 01:38 PM
Chucks ss Chucks ss is offline
Default K301 runs good for 10 min then sputters and dies
Motor is in 123 hydro starts up good runs good for like 10 min then starts to sputter and eventually dies. I have noticed. The carb gets so hot. The fuel vaporizes. As soon as its squirted. Not saying thats a prob. But. Just an observation. Also just changed head gasket i have a carb rebuild kit. Havent used it. Yet. The gov keeps surging back and forth ive noticed as well ok. So any ideas.
Old 08-18-2017, 05:03 PM
The surging governor indicates that it's running lean, i would look for a restriction in the fuel system.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-18-2017, 06:29 PM
X2. First try adjusting the main jet counter clockwise and see if the surging goes away.
Old 08-19-2017, 12:12 AM
Backed main jet out still same issue. Prob go ng to pull the carb. And. Clean. It.
Old 08-19-2017, 07:47 AM
mrfred54 mrfred54 is offline
make sure fuel cap vent is open and fuel drains from tank with good stream
Old 08-19-2017, 01:50 PM
Check the flow from the tank, you might not be getting enough flow to keep the carb full which would make it run lean and eventually die.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-19-2017, 02:34 PM
Update. Got a carb overhaul kit. Just because. It sat for 20 years. Turns out there was blockage where the fuel line goes into the carb. Littke black pieces. So cleaned. And put back together. Runs perfect. Main jet backed off turn and a half.
This is why i love this. Site. Thank you.
Old 08-19-2017, 02:49 PM
Main jet is normally out more than that.... Yeah, I know. You're going to say that's where the book says to set it. That's a starting point. They most always need to be out further.
Old 08-29-2017, 09:22 PM
jcsmith jcsmith is offline
Default new fuel line
Did you replace all the fuel line? If not it will happen again.
Chris
1968 104 , service replacement '96 K301, 42" deck
1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck
2007 LA130,21hp Intek v-twin, 48" deck
As you slide down the banister of Life, may the splinters point in the right direction .
Old 08-30-2017, 09:17 AM
Baccarat Baccarat is offline
X2 on the fun line replacement. You also might want to investigate where those little black pieces came from. Perhaps a complete fuel system clean out starting with the fuel tank all the way to the carb is in order. Those little black pieces came from somewhere. The question is where?
